I am still having problems reading in my dems. This is the output from the command m.dem.examine. Note the resolution (0)
MINDEGO HILL,CA BIG BASIN DEM DLG-DEM
min elevation: 224.000000 max elevation: 2816.000000
ns_res: 0.000000 ew_res: 0.000000
# of columns in file = 809773872file north UTM = 4136628.750000
file south UTM = 4122665.750000
file east UTM = 577600.937500
file west UTM = 566405.250000
-------------------------------Danimal
We were having trouble with importing a DEM recently and it turned out
to be the way we were reading the tape and NOT the m.dem.extract command.
Make sure that when you are reading your tape that you are using a
variable record length so that you get the last block that is not always
a full record length. This took care of our problem.
Joyce A. Nagle
U.S. Army Cold Regions Research and Engineering Laboratory (CRREL)
Remote Sensing and GIS Center email: nagle@hanover-crrel.army.mil
72 Lyme Road phone: (603) 646-4161 / 4100
Hanover, NH 03755-1290 fax: (603) 646-4278
