Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro@zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: dem extraction & examine
Message-ID: <C3I4Ho.8st@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9302191938.AA02409@rogue.geo.duke.edu>
Date: Sun, 7 Mar 1993 04:29:48 GMT
Lines: 65
In <9302191938.AA02409@rogue.geo.duke.edu> riker@rogue.geo.duke.edu (Dan Riker) writes:
m.dem.extract has been worked on a lot. The problems are not GRASS vs
sparc stations, but partly due to the variability in the DEM format
supplied by USGS. The new m.dem.extract (on the moon and in 4.1)
tries to be more flexible about the USGS "formats" as well as allowing
for input from disk files. Note that this program only expects DEM
data, but USGS will distribute tapes that have both DEM and DLG data,
and some of the DEM formats are incorrect. The DLG data must be
eliminated when copying to disk, but some of the DEM format problems
m.dem.extract can work around. But, note, this is not true of
m.dem.examine, which was retained unaltered. You can run an
examine using m.dem.extract (newer version) by simply not specifying an
output layer.
Hello there, I hope you all are doing well.
I am still having problems reading in my dems. This is the output from the command m.dem.examine. Note the resolution (0)
MINDEGO HILL,CA BIG BASIN DEM DLG-DEM
min elevation: 224.000000 max elevation: 2816.000000
ns_res: 0.000000 ew_res: 0.000000
# of columns in file = 809773872
file north UTM = 4136628.750000
file south UTM = 4122665.750000
file east UTM = 577600.937500
file west UTM = 566405.250000
This is the outcome of the command m.dem.extract (using an exabyte tape, but the same shows for the 1/2 inch tape):
enter option > 1024
You have chosen:
blocksize=1024
Is this correct? (y/n) [y]
Current Window Settings-----------------------------
rows: 1173
cols: 1167
north: 4130200.000000
south: 4095000.000000
east: 590000.000000
west: 555000.000000
ns_res: 30.008525
ew_res: 29.991431
Reading Elevation Tape...
ERROR: error reading tapeMapset <PERMANENT> in Location <california>
GRASS 4.0 >
Does anyone have an idea about what is going on here? I have heard rumors recently that GRASS and Sun Sparcstations don't get along. Is that the problem?
I would sincerely appreciate any help on these matters.
Danimal
Michael Shapiro U.S. Army CERL
Environmental Division
