Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro@zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: displaying maps from within xgrass
Message-ID: <C3I68y.972@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9302251711.AA08423@st.unocal.com>
Date: Sun, 7 Mar 1993 05:07:46 GMT
Lines: 24
In <9302251711.AA08423@st.unocal.com> stssmap@nagina.unocal.com (Mark Palm) writes:
There any number of things that coudl be wrong:
(1) is the etc/monitorcap setup correctly. This file
isn't installed automatically. You have to edit it.
(2) the fifos used to communicte with the driver have to
(a) agree with what is in etc/monitorcap and
(b) be read/write for everyone
(3) The DISPLAY varible for X applications needs to be set
(you can check this just by running an xterm - if that
works than DISPLAY is set. If not, then either DISPLAY is
wrong, or refers to another host which will have to permit
you to use it as a server - via xhost)
(4) The lock directory has to be writeable by everyone, otheriwse
the GRASS locking mechanism will fail.
d.mon start=x0 does not establish the use of graphics display terminal on a
Sun sparc 2. What environment variables have to be set before running xgrass?
Also, is there any documentation in the grass directories on setting these
variables?
Michael Shapiro U.S. Army CERL
Environmental Division
