This topic needs a title
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro@zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: NO carriage/return & line/feed
Message-ID: <C3I70v.9J0@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <Pine.3.05.9302260734.A24664-a100000@ptolemy.geog.umn.edu>
Date: Sun, 7 Mar 1993 05:24:31 GMT
Lines: 28
In <Pine.3.05.9302260734.A24664-a100000@ptolemy.geog.umn.edu> harry@atlas.socsci.umn.edu (Kuo-Chen Chang) writes:
Hopely someone can help me out of this mystry.
I just installed GRASS4.1BETA under Linux. With some minor modifications,
the new GRASS is up and running. So far, it is fine except the text display.
It seems to me that there is no carriage/return and line/feed. The output
just dump onto screen as a long long single line. But when you are in a
module, for example, r.buffer, the display is fine.
The losing of CR/LF continues even after I exit GRASS. Any comment or
suggestion is warmly welcome. Many thanks!
--Harry
ps, I suspect, there's something related to termcap that I have to change.
You don't have to change termcap. It is GRASS/Unix curse at fault. The
workaround may be to type
  LINEFEED reset LINEFEED
Michael Shapiro U.S. Army CERL
Environmental Division
