This topic needs a title
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!irina
From: irina@zorro.cecer.army.mil (Irina Kosinovsky)
Subject: Re: Errors in v.proj, m.get.stp, & m.setproj
Message-ID: <C3yFJC.MBM@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9303151721.AA26577@niwot>
Date: Mon, 15 Mar 1993 23:50:00 GMT
Lines: 53
In <9303151721.AA26577@niwot> ront@niwot.CFNR.ColoState.EDU (Ronald Thomas) writes:
GRASSusers,
I reported an error to the bugs.list, and want to share it with the general
users.
When using m.set.stp or m.setproj to set up a state plane projection in a
mapset, beware of errors. Here in northern Colorado, these programs select
the central Colorado state plane zone (502) for Larimer County, when in
fact, the county is in the northern zone (501). If you use v.proj to
transform data, be aware that it uses m.setproj to create projection
reference files in the new state plane mapset, and its output should be
checked for errors.
I assume you are talking about old (SCS) version of v.proj.
The new version (about to get released) gets the state plane zone
from PROJ_INFO file in your location (which you can create using g.setproj)
Now that I have data transformed from my UTM mapset to a state plane
mapset, I'm having trouble setting/changing the region within the state
plane mapset. Am I correct in assumming that in order to make full use
of the state plane data, I must copy the state plane mapset from the UTM
location into a separate State Plane location?
The new v.proj will put the resulting vector file into the right location
for you (it lets you for example convert a vector file in UTM location A
to a State Plane vector file in location B (which is State Plane), so
you don't have any problems with having both UTM and State Plane mapsets
in the same location -- i.e. each location has its own projection.
  Ronald Thomas ^ ront@meeker.cfnr.colostate.edu
   Natural Resources Spec. (GIS) ^
    Resources Management Division ^ Phone: 303-586-3565 x285
     Rocky Mountain National Park ^ 700-323-7285 (FTS)
      Estes Park, CO 80517 ^
Irina Kosinovsky [irina@zorro.cecer.army.mil]
Construction Engineering Research Labs, US Army Corps of Engineers
Champaign, Illinois (217)352-6511 x676
"See, when the GOVERNMENT spends money, it creates jobs; whereas when the
money is left in the hands of TAXPAYERS, God only knows what they do with it.
Bake it into pies, probably. Anything to avoid creating jobs." -- Dave Barry
