This topic needs a title
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro@zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: grid
Message-ID: <C4HH7L.LMn@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9303250118.AA00827@mqnimbus.cic.mq.edu.au>
Date: Fri, 26 Mar 1993 06:40:32 GMT
Lines: 23
In <9303250118.AA00827@mqnimbus.cic.mq.edu.au> cathy@mqnimbus.cic.mq.edu.au (Cathy Ciret) writes:
I send another message,the previous one (grid and contour) was
probably not clear enought.
I tried to be able to know visually how many cells I've got in
my raster maps ,so I need to put a grid with rectangular :
dimension 4.5 lat,7.5 lon.So far,I couldn't get anything
like this with d.grid,when I enter the coordonnes in size=values
it doesn't work.
My questions are:can we get a grid with rectangular cell,and how?
Is there another command which give the possibilities to overwrite
this grid on the raster map(i.e get this grid permanently)
Thanks for your help.
Cathy
d.grid only allows square grids. That isn't its only drawback. YOu can't
specify the origin of the grid. The only other tool which will do what
you want is d.mapgraph.
Michael Shapiro U.S. Army CERL
Environmental Division
