Lines: 23> > In <9303250328.AA09050@> markp@per.dms.csiro.au writes:
>I have installed grass4.1beta on a sparc 2 and it seems fine. I have no
>problems starting a monitor from either the sparc or from an
>Xterminal. However, when i rlogin from a decterm (5000/25 ultrix 4.2a,
>with Motif) and try to start x0, say, the windo flashes up, i get the
>message about it being started and then an error message about not
>being able to select it. The rlogin is from the dec to the sparc.>Anyone got any suggestions?
>(The locks/sparc/dec directory appears to be created ok)
This is common. It is a timing problem. d.mon tries to select
the monitor twice (if it fails the first time). Try running d.erase
to see if the select actaully worked. Or use thius sequence
d.mon -s start=x0 # start, but don't select
d.mon select=x0
--Michael Shapiro U.S. Army CERL
Environmental Division
Well, I tried this, the monitor window appeared to stay for a little longer
(probably a second before disappearing) but one could not then select it
