Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!youngs
Subject: recommendations on pc dos versions of X ?
Message-ID: <C4qGE4.KC7@news.cecer.army.mil>
Summary: seeking recommendations for pc dos versions of X
Keywords: recommend, pc dos X
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
Date: Wed, 31 Mar 1993 03:01:16 GMT
Lines: 7
Anyone have any recommendations on pc dos versions of X that can be used
to run grass ?
We use HCL-eXceed/W, It is an X emulation package which runs with ms-windows.
It works fine, even with 16 color VGA, allthough you will have very limited
standard color possibilities for displaying vectormaps e.g. We noticed one
problem when using HCL-eXceed: When using d.zoom the GRASS-window is erased.
This can be solved, by modifying the Xdriver wich comes with grass.
We have a novell netwerk installed with LAN workplace for dos, but you can
also use other TCP software. We also tried Desqview/X from Quarterdeck,
this program didn't work with grass, It had problems with grass-colortables.
