Newsgroups: info.grass.user
Path: lily.aerc.colostate.edu!paul
Subject: Color problem with hpvue on an HP 720 and grass4.0
Sender: news@yuma.ACNS.ColoState.EDU (News Account)
Message-ID: <Apr01.154340.62236@yuma.ACNS.ColoState.EDU>
Date: Thu, 01 Apr 1993 15:43:40 GMT
Nntp-Posting-Host: lily.aerc.colostate.edu
Organization: USDA-ARS-WMU, Ft. Collins, Colorado
Lines: 32
We have an HP 9000/720 (HP-UX 8.07) and I want to run grass 4.0 under
hpvue (version 2).
When using the hpvue environment, I have been able to produce
less than desirable results using vuewm or mwm.
Under hpvue there is some inconsistency with color usage by hpvue vs.
how a grass graphics display uses colors.
If I specify a specific color (say yellow) when I do a d.vect I
can see lines being drawn in the graphics display window but they
are not yellow. If I click in the grass display window then the lines
switch to the correct colors. However, the rest of the screen goes black
and I can't see any thing else on the monitor.
By the way if I use the resident mwm on an xtermial and log into the HP there
is no problem. I can see all windows simultaneously and the colors
are correct.
If I start up mwm (under hpvue) I have the same problem as as when I use
vuewm.
Has anyone else had this problem? If so is there any way around the problem?
Thanks
Paul
Paul F. Williams Internet: paul@lily.aerc.colostate.edu
Work: (303)491-8277 Fax: (303)491-8247 Home: (303)484-1149
