This topic needs a title
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro@zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: importing sun rasterfiles
Message-ID: <C80153.ECu@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9306010336.AA13807@cerberus.earth.monash.edu.au>
Date: Wed, 2 Jun 1993 14:48:39 GMT
Lines: 22
In <9306010336.AA13807@cerberus.earth.monash.edu.au> simon@cerberus.earth.monash.edu.au (Simon Cox) writes:
I just tried to use r.in.sunrast and it complained
" - this rasterfile format not supported"
My files are
" rasterfile, 3074x1938x8 run-length byte encoded image"
Is it the run length encoding which is the problem?
If so, is there any way to convert this *without* going
all the way to ascii (I think my machine might get indegestion!)
I'm using grass4.0.
Yes, this is the problem. Can you recreate the images in standard format?
You could use the pbmplus utilities.
Michael Shapiro shapiro@zorro.cecer.army.mil
U.S. Army CERL (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
