Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro@zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: G_realloc: out of memory
Message-ID: <C8q1qA.Any@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9306071409.AA25785@nps.unm.edu.NPS>
Date: Wed, 16 Jun 1993 15:58:58 GMT
Lines: 24
In <9306071409.AA25785@nps.unm.edu.NPS> doug@nps.unm.edu (grass) writes:
When running r.support on an image I find this error.
Does anyone know what I can do to run an update on the stats
for this image?
Doug Bradley
UNM-CPSU ALB
The file that r.support is trying to update is cell_misc/<map>/range
which is a one line ascii file with 4 numbers: nmin nmax pmin pmax
(corresponing to the min and max range for the negative and positive
values in your raster map). Try
r.describe -r <map>
The -r option for r.describe doesn't require as much memory and will
tell you the values you need for nmin, nmax, pmin, pmax. Then create
the range file "by hand".
Michael Shapiro shapiro@zorro.cecer.army.mil
U.S. Army CERL (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
