This topic needs a title
How to set default region in GRASS?
thankyou
Subbarao Vedula
Subbarao Vedula (Subbarao.Vedula@eng.auburn.edu) writes on 9 Nov 93:
Subbarao,
This is usually done when you create a location.
If you want to change your "current" region
(and not your "default" region), use the g.region
command.
To change your default region, you will need to edit
$LOCATION/WIND, but this is not recommended unless you
know exactly what you are doing.
--Darrell
James Darrell McCauley, Purdue Univ, West Lafayette, IN 47907-1146, USA
mccauley@ecn.purdue.edu, mccauley%ecn@purccvm.bitnet, pur-ee!mccauley
** will finish PhD/engr in 9/94 - need job. inquiries welcome (no hh, plz) **
Darrell McCauley (mccauley@ecn.purdue.edu) writes on 9 Nov 93:
opps, DEFAULT_WIND, in PERMANENT.
