From grass-lists-owner@max.cecer.army.mil Tue Jul 26 22:06:20 1994
Subject: Question about Viewing DLG files in GRASS
Date: 27 Jul 1994 03:57:15 GMT
Organization: Statistics Dept., U. C. BerkeleyI have spent the last two days trying to view DLG files in GRASS
that I installed on a SUN workstation and I am feeling rather
frustrated. I would be very obliged if someone knowledgeable
could tell me what I am doing wrong....
USGS-NMD DLG DATA - CHARACTER FORMAT - 09-29-87 VERSION
SAN FRANCISCO, CA 1978, 100000. F08
>^@^@^@\0 0 3636
3 1 10 2 0.25400000000D+01 4 0 4 1
-0.122007030000000D+09 0.370370300000000D+08 0.000000000000000D+00
0.000000000000000D+00 0.000000000000000D+00 0.000000000000000D+00
0.10000000000D+01 0.00000000000D+00 0.00000000000D+00 0.00000000000D+00
SW 37.500000 -122.250000 566295.14 4150401.44
NW 37.750000 -122.250000 566072.83 4178137.43
NE 37.750000 -122.000000 588098.80 4178342.21
SE 37.500000 -122.000000 588392.23 4150606.89
RAILROADS 0 142 142 010 29 29 010 169 169 1
N 1 566295.14 4150401.44 2 0 0
163 -8and when I finally finished with g.region it looked like this:
IDENTIFY REGION
============================= DEFAULT REGION ========
| Default North:37:45N |
| ======= YOUR REGION ======= |
| | NORTH EDGE:37:45N_____ | |
Def. West |WEST EDGE | |EAST EDGE | Def. East
122:15W |122:15W____| |122W_______| 122W
| | SOUTH EDGE:37:30N_____ | |
| Default South:37:30N |
PROJECTION: 3 (Latitude-Longitude) ZONE: 0Default GRID RESOLUTION Region
0:00:06.47482st-West --- 0:00:06.47482
0:00:06.47482th-South -- 0:00:06.47482AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
(OR <Ctrl-C> TO CANCEL)...
Thanks again in advance.
Shaji
Shaji,
When you import an optional format dlg file, it is in
UTM coordinates. The header you created is in lat-long.
You need to use the UTM coordinates:
north: 4178342.21
south: 4150401.44
east: 588392.23
west: 566072.83
and you appear to be in UTM zone 10.
The person who suggested using the command: g.region vect=(filename)
is correct, this will set the region to whatever the region is for the
vector file you created...
Hope this helps.
Susan Stitt
National Biological Survey (303) 969-2596
Technology Transfer Center sstitt@its.nbs.gov
