20 June 1997
My Supervisor forwarded an E-Mail from the GRASS group concerning the
operation of GRASS on Linux OS up-grades.
I started with an old version of Linux, installed GRASS (from the
port that "Andy" in Germany sold on CD) and worked my way through a
couple of upgrades. My current Linux OS is ver> 2.0.27....
I still have no problems with GRASS!!
Using "Andy's" CD, I've never had a problem with GRASS. If I do a "fix"
in a script for LINUX/GRASS, I then run that same script on both our
Sparc compile of GRASS and our DEC compile of GRASS and get identical
results across all three. And people, that is as good as it gets.
A small history might help.
I tried to upgrade to Slackware 3.2 (the 4-disk set from Walnut Creek
CDROM), but a number of things didn't work very well and some not at
all. I am a member of a "book of the month" type club and timing can be
everything. I had ordered a tile: "The LINUX Internet Server" by Kevin
Reichard (Patrick Volkerding contributing); The MIS Press, 115 West 18th
Street, NY,NY 10011, http://www.mispress.com; ISBN 1-55828-545-8
copyright 1997; price marked as $40 (US dollars). It arrived while I was
cursing the Slackware 3.2 problems and there was a CD-ROM in the book. I
used it and my problems with LINUX went away. I then re-loaded GRASS and
I do not have any GRASS problems.
I do NOT use the g++ or any other compiler that wants to be COBOL. I
only load (from the OS) just what is needed and seldom anything else.
Just as no one car can be both a Formulae One and an off-road vehicle,
the same is true of your computer configuration. Keep it "lean, mean &
to the point" and you will have far less problems.
Also keep in mind that UNIX is not a true OS. It is a community, at
best. Don't adopt their standards. Instead, be efficient. Keep your
things in tight (don't get scattered around). Use names and paths that
are consistent with iso-9660 standards (cd-roms) and file
sharing/distribution problems disappear. (but teacher said....) OK, the
professor at university may well be a walking enceclopedia. This was
valuable before the time of books. Professors live in a vacuum like
books on a shelf and I've never seen an encyclopedia build a bridge I
would walk across.
And lastly - approach all things today cited as "NEW &/or BETTER"
with total distrust. (It usually means - "You get to debug it because I
wouldn't/couldn't".) The Missouri State slogan is "Show Me!". Adopt it.
Demand it.
Steven L. Turner LLS stevet@water.ca.gov
GIS Tech. Support
Land & Water Use Unit
Statewide Planning Section
Division of Planning and Local Assistance
Department of Water Resources
State of California
1416 9th Street, Rm 150
Sacramento, CA 95814
