This topic needs a title
(5.65a/IDA-1.4.2b/CC-Guru-2b)
        id AA29765 (mail destined for houston@mgm.lan.mcgill.ca) on Fri, 29 Jan
93 13:53:50 -0500
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA03785
  (5.67a/IDA-1.5 for <houston@mgm.lan.mcgill.ca>); Fri, 29 Jan 1993 12:53:24
-0600
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
  id AA28819; Fri, 29 Jan 93 12:49:14 CST
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA10375
  (5.67a/IDA-1.4.4 for <grassp-people@amber>); Fri, 29 Jan 1993 12:49:13 -0600
Received: from nic.cerf.net by amber.cecer.army.mil (4.1/SMI-4.1)
  id AA28813; Fri, 29 Jan 93 12:49:10 CST
Received: by nic.cerf.net (4.1/CERFnet-1.0) id AA18839; Fri, 29 Jan 93 10:51:34
PST
Date: Fri, 29 Jan 1993 10:51:34 PST
Message-Id: <9301291851.AA18839@nic.cerf.net>
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassp-list@max.cecer.army.mil
Precedence: Bulk
Sender: lists-owner@moon.cecer.army.mil.
Reply-To: grassp-list@moon.cecer.army.mil.
Precedence: Bulk
To: grassp-list@amber.cecer.army.mil
Subject: Problem of graphic window resize and repaint
Cc: pklin@cerf.net
PoKung Lin:
I have compiled GRASS4.0 source under INTERACTIVE UNIX System V/386 Release 3.2
with X11 Release 4. When I ran the grass4.0, I found that if we kept the grass
window
to its default size, every command seems working OK. But if we enlargeed
the grass window, the following problems would accur:
       1. The d.display will only show the frame, the GRASS icon, and
       the region information. When it came to display the popup menu, the
       whole grass window disappeared.
       2. After the grass window got resized, the 'd.' commands (exccept
       the d.display mentioned above) still work. But if there was any
       window (e.g. shell window) overlapped on top of it and if we
       moved the overlapped window away, the grass window only got repainted
       to its default size and left the rest of the grass window black.
The development system I am using is the INTERACTIVE Workstation Developer
which
got from SunSoft dealer last December. The GRASS 4.0 source came from the
Young Mind CD.
Is there any people using INTERACTIVE development system to compile grass4.0?
Do you have the same problems? How do you solve the problems? Any hints to
resolve the problems is highly appreciated. Thank you in advance for your
help.
I have also been attemptng to get GRASS 4.0 to run under Interactive UNIX
V/386 Release 3.2 Version 3.0.1 with the Interactive Development Package.
With the Initial Distribution of GRASS 4.0 (Summer 1991), I also had
troubles with large X Windows which would disappear and d.display that
had real problems. What I found to work "better" (from the large windows
point of view) is the XDRIVER update which is available via anonymous FTP
at max.cecer.army.mil (IP Address is 129.229.20.254) in the directory:
"/grass/grass4.0/updates/src/display/devices/XDRIVER/XDRIVER". It works
well for displaying in the larger windows and has new features such as
a driver name (x0, x1, x2 ....) and automatic regeneration upon resizing,
but the "rubber banding" is painfully slow (and that was OK in the orginal
version)!
Some other problems which I have also seen are crashs with some Vector Files
and the full-screen text mode which freezes upon defining the coordinates
for a new mapset (but works correctly for modifying existing mapset
coordinates!). Temporarily I have been editing the WIND and DEFAULT_WIND
by hand (vi), as a work around. So far I have not been satisfied with
GRASS 4.0 as it is presently running under Interactive UNIX. At the
University we run GRASS 4.0 on SUN WorkStations and there are no problems,
but this System V Release 3.2 does not appear to be compatible enough with
the basic GRASS Code. I had big plans of getting it into a fully working
state, but so far time has been in short supply and the problems may not
be straight forward fix. Not sure if by myself it will ever reach
completition as I had initially planned?
                                  Lawrence Houston .....
| Lawrence Houston (HOUSTON@MGM.lan.mcgill.ca) |
| Department of Geography - McGill University |
| GGGGGGG IIIIIII SSSSSSS |
| G G I S S |
| G I S |
| G I SSSSSSS |
| G GGGG I S |
| G G I S S |
| GGGGGGGG IIIIIII SSSSSSS |
Acknowledge-To: <houston@mgm.lan.mcgill.ca>
