This topic needs a title
Newsgroups: info.grass.programmer
Path: vinny.cecer.army.mil!pirzyk
Subject: Re: XGRASS Problem
Message-ID: <CA9Esv.CL4@news.cecer.army.mil>
Sender: news@news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9307161141.AA00919@mishell.usda.msu.edu>
Date: Fri, 16 Jul 1993 13:29:19 GMT
Lines: 34
In <9307161141.AA00919@mishell.usda.msu.edu> brent@mishell.usda.msu.edu (Brent Stinson) writes:
Hello People,
I pulled down the binary version of 4.1 from the moon a little while
ago for a SUN SPARC IPC running SUNOS 4.1.3 and Openwindows3.
GRASS4.1 seems to run fine, but when I try to start XGRASS I get the
following errors:
Warning: translation table syntax error: Unknown keysym name: osfActivate
Warning: ... found while parsing '<Key>osfActivate: ManagerGadgetSelect() '
Warning: translation table syntax error: Unknown keysym name: osfSelect
Warning: ... found while parsing ' <Key>osfSelect: ManagerGadgetSelect() '
Warning: translation table syntax error: Unknown keysym name: osfHelp
Warning: ... found while parsing ' <Key>osfHelp: ManagerGadgetHelp() '
Warning: translation table syntax error: Unknown keysym name: osfBeginLine
Warning: ... found while parsing ' <Key>osfBeginLine: ManagerGadgetTraverseHome() '
etc
etc
etc
Your missing a file on the new system called.
/usr/lib/X11/XKeysymDB.
Just copy it over from the old system and that should solve the problem.
- Jim Pirzyk
[Jim] pirzyk@uiuc.edu ------------------------------------------
TAC & GrassNet System Administrator, US Army Corps of Engineers
Construction Engineering Research Labs, Champaign IL USA
