Hi.
I tried to compile C-code of my application under IRIX5.2 using
the same Gmakefile and environment variables as used before
under IRIX4.x. Compiler created all object files, but ld
gave the following Error message:
ld:
Object file format error in:
/Users1/lopresti/sergeyva/grass/src/libes/LIB.sgi/
libvect.a(open.o): cannot mix Elf and COFF objects.
*** Error code 1 (bu21)
Could you, please, tell me what Elf and COFF objects are, and
what should be fixed in that situation?
-Vitaly Brukhman
