It is ok to change the region without closing the raster file.
The raster map will respond to the new region without
closing/reopening. You just have to reallocate the i/o buffers.
But see if you can prove that the cell file open/close is the
culprit. If it is, then we have another bug to fix.Michael
Yes, I think the open/close of raster map is the cause for this problem.
I have two menus, with one as main and other as sub-menu.
Each time when I enter to the sub-menu and perform open a raster map
the file descripter id increased by 3. If I perform any number of operations
in the same sub-menu the file descripter remains the same.
However, If I leave from the sub-menu and re-enter to the sub-menu
the file descripter of a raster map increases by 3. By the way I am closing
the raster map each time as soon as finish reading the data.
One thing to keep in mind, that whenever I enter in to a sub-menu
I am displaying atleast 3 raster maps on the graphics window using the
"Dcell" function provided by the "D_lib". Since, the function "Dcell"
also performs open/close of raster map.
Can any one see through this problem. Any suggestions are appreciated.
Thanks.
Srinivasan.
srin@ecn.purdue.edu
