Any grass programmers still left out there?
Sure.
I get "WARNING: too many open raster files" after about
20 iterations of a dynamic simulation model that uses
r.mapcalc and other GRASS programs, as well as some
contributed code. If I omit the following subroutine in
our contributed code, then the program does not produce this
error, so this is the offending code, although other things
going on elsewhere could be contributing other open
raster files (?):
There are two aspects to this problem (I think). The first is
the origin of the warning. This warning is produced in
file src/libes/gis/opencell.c if you try to open more than
MAXFILES files. MAXFILES is a constant that is #defined to be
30 in src/libes/gis/G.h
I don't know why it's 30, probably the programmers thought that
nobody in their right mind would need more than 30 open files
anyawy (sounds vaguely familiar...).
So I guess you could change this constant and recompile GRASS
(you'd probably need to recompile or at least relink just about
all of GRASS since this is a fairly central point).
The second aspect is that your use of more than 30 open files
_may_ point to a resource leakage. On the other hand, a complex
mapcalc calculation could easily lead to a large number
of temporary files (I don't know what mapcalc does in main-memory
and where it uses temp files; a look at the code might help there).
If your program is a complex one that opens and closes raster files
all over the place, a debugger might help. Set breakpoints in
the relevant routines (G_open_cell etc., recompile them with
debugging information if necessary) and check if close
is called often enough etc.
Finally, I only use G_gisinit at the beginning of my GRASS programs
(mostly in main()). Calling it in a subroutine makes sense if that
routine is the only one that uses GRASS code, but calling it
more than once might have funny effects on some bookkeeping
details, maybe including file descriptors.
Good luck, Martin
void probascii();
int fd;
char *mapset;
static char prog_name = "probascii";
static char filename = "DISTPROB";G_gisinit(prog_name);
if((mapset = G_find_cell(filename,"")) == NULL) {
printf("Unable to find file %s.\n",filename);
exit(1);
}if((fd = G_open_cell_old(filename, mapset)) < 0) {
printf("Unable to open file %s.\n",filename);
exit(-1);
}...CODE OMITTED
G_close_cell(fd);
I didn't write this code, but I'm trying to debug it.
Anyone see why this fails to close the raster files?
Or, any other clues as to what else could be
producing this WARNING?Bill Baker
BAKERWL@UWYO.EDU
Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
Kiel University, Olshausenstr. 40, 24118 Kiel, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
ma@informatik.uni-kiel.de, URL http://www.informatik.uni-kiel.de/~ma/
