Thanks to Bill Baker, Michael Hanratty and others for bringing up the issue
to the attention of the GRASS community and providing hints to solve the
problem. The solution is to replace the line
#define MAXFILES 30
in src/libes/gis/G.h with
#define MAXFILES 32000
The problem is that MAXFILES was used to compare with fd (file descriptor)
which is NOT a counter of open files in a process. fd is assigned by the
system and it can be greater than MAXFILES even if the actual number of
open files is less than MAXFILES. Since UNIX has a system level variable
OPEN_MAX (default = 64 for Solaris, 256 for some LINUX) it is safe to let
the system control the number of open files. By assigning a large number
to MAXFILES, we simply make the following statement in opencell.c &
closecell.c always FALSE.
if (fd >= MAXFILES)
Therefore, no other parts of code need to be modified. A safe fix to the
problem.
For questions or comments on this fix please contact:
support@gpz.com
To get the GPZ source patch file for GRASS 4.2.1 version 16, go to GPZ's
home
and click on a hyperlink near the top of the page. The patch file is being
sent to Markus Neteler.
George Chou
GPZ Technology
gchou@gpz.com
GRASS-XMI - A Simple, Low-cost, Efficient and User-friendly tool for
GRASS. Version 1.3 is coming on June 25, 1998 -- http://www.gpz.com
To: grassu@cecer.army.mil
Subject: Re: Too many raster files open
Date: Wednesday, June 18, 1997 2:11 PMI have figured out the problem:
In message <9706130905.ZM27213@impact1.hpcc.nectec.or.th> writes:
> Bill and Michael,
> On Jun 12, 2:50pm, William L. Baker wrote:
> > No one had a remedy, but someone did point out where the
> > message comes from, but now when I look I see that I've lost that
> > information.
> I have a copy of the reply to Bill's posting from Dec 19, 1996 I
include the
> entire message below.
<snip> >
> > There are two aspects to this problem (I think). The first is
> > the origin of the warning. This warning is produced in
> > file src/libes/gis/opencell.c if you try to open more than
> > MAXFILES files. MAXFILES is a constant that is #defined to be
> > 30 in src/libes/gis/G.h
> > I don't know why it's 30, probably the programmers thought that
> > nobody in their right mind would need more than 30 open files
> > anyawy (sounds vaguely familiar...).
> > So I guess you could change this constant and recompile GRASS
> > (you'd probably need to recompile or at least relink just about
> > all of GRASS since this is a fairly central point).
The problem is that the MAXFILES is compared to the file pointer, fd,
which is
never decremented. Each new file opened is added as the next higher
file. So,
it doesn't matter how often you close files, if you open more than
MAXFILES
during a program run, then the program will abort. The best fix would be
to
have a static variable that is shared by the opencell and closecell
programs
that is incremented and decremented when a file is opened and closed,
respectively. Then MAXFILES would be compared to the actual number of
files
open, instead of the number of files that have been opened since the
program was
started.
Has anyone done this fix?
Michael Hanratty Phone: (612) 627-4590
St. Anthony Falls Laboratory Fax: (612) 627-4609
Dept. of Civil Engineering
University of Minnesota
Mississippi River @ 3rd Ave. SE
Minneapolis, MN 55414
