Hello GrassUsers:
I want to interpolate a scarse data points, but well choised, to set
a raster map. These points are localited in change zones.
For this I want first to make a interpolation of triangulation type,
to create a thing similar to a TIN and from this to interpolate to a coarse
grid. Subsequently to reinterpolate this grid to a more fine grid with
"s.surf.tps" for smooth.
PROBLEM: Running "s.geom operation=delaunay" I obtain a vector map with
triangular polygons whose category (dig_cats) is the Z value of the 3 vertex
of this triangle. When I convert this vectorial map to raster with
"v.to.rast", it creates a raster map which reflects the previous polygons;
beeing the category cell too the Z values of the original vertex.
I want to know how can I use the vectorial map created by "s.geom"
to obtain a raster map, where every cell have as category their corresponding
Z value in the tridimensional triangular surface built by the original
vertexs.
Thanks in advance.
Evaristo
__ __
/ / Evaristo QUIROGA RAIMUNDEZ / /
___/ / ___/ /
/ / UNIVERSIDAD AUTONOMA DE BARCELONA / /
\__/\\ Gabinete de Analisis Territorial y Ambiental \__/\\
\\__ Unidad de Geodinamica Externa y Hidrogeologia \\__
/ /\ Edificio CS / /\
\ / /\ 08193 - Bellaterra (BARCELONA) \ / /\
\ / \ SPAIN - EU \ / \
\___/ email: evaristo@cataw.uab.es \___/
