Trimble GPS input
And the winner is....
Thanks to all who replied, I used Mr. McCauley's suggestion and modified
the asc_to_bin.c file at src/mapdev/v.in.ascii and switched the x & y in
line 81. I also went into the Gmakefile and changed references to "v.in.ascii"
on lines 22 & 24 to "v.in.trim" and then re-compiled. After running MAKELINKS,
I have a nifty new utility named "v.in.trim" that reads a**-backwards Trimble
output. (Or is it the original "v.in.ascii" that's a**-backwards?!)
Again, thank you to all who replied!!!
Ronald Thomas ront@meeker.cfnr.colostate.edu
Natural Resource Spec. (GIS) ^^^ Phone: 303-586-3565 x285
  Resources Management Division ^^ ^^^^^ FAX: 303-586-4702
   Rocky Mountain National Park ^^^ ^^^^^^^ Estes Park, CO 80517
