I got a problem with my new grass5 installation. When I try to start a
monitor I get the message:
" Sorry, permissions on </usr/local/grass/dev/fifo.1a> (644) should be
0666 Have GRASS administrator check etc/monitorcap file "I can't see what's wrong with my monitorcap file
there is nothing wrong in your monitorcap file, but the "fifos" seems
to be damaged or having wrong permissions. No problem:
1. Change the permissions as root:
- go to grass5/dev/
- chmod 0666 fifo*
That's it.
If that does not help:
2. Create new fifos:
- go to grass5/dev/
- look for the fifo-creating script create_fifos.sh
If not there (should be), get it from:
Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
- rm fifo* (throw the old ones)
- run the script to generate new fifos:
sh create_fifos.sh
Feel happy.
Best wishes
