trouble with d.mon under linux
Dear all,
I just finished installing Grass5beta6 (intel PC with linux redhat 6.1),
but when I try opening a window I get the following error:
                    MONITOR MENU
Making sure that the graphics monitor is running
     1 - start a graphics monitor
     2 - stop a graphics monitor
Choosing a graphics monitor for your graphics
     3 - select a graphics device for output
RETURN - quit
1
Enter name of graphics monitor to start
Enter "list" for a list of known monitors
Enter "list -f" for a list with current status
Hit RETURN to return to menu
x6
can not allocate any read/write color cells
Problem selecting x6. Will try once more
hit RETURN ->
Obviously, after this error I cannot do anything...
I tried to follow some suggestions in the grass FAQ's, but it didn't help.
Could someone please help me?
thank you in advance
Andrea,
More than likely your video card is the culprit (not having enough power in
some older cards). To fix this, you may try shutting down any
other color-intensive programs you may be running (Netscape, graphics
and drawing software, etc.). Then restart GRASS and things should
be ok for you. Let me know if this doesn;t work.
Bruce
Bruce Byars
GRASS Dev. Team
CAGSR - Baylor Univ.
Andrea Bistacchi wrote:
Dear all,
                    MONITOR MENU
RETURN - quit
> 1
> x6
hit RETURN ->
Dear all,
run xdpyinfo (/usr/X11R6/bin/xdpyinfo)
scroll through the output looking for
  depths (2): 1,8
this means you are running a 8 bit display
If this is not true ignore all of the rest of this message.
GRASS 24 bit XDRIVER has problems if:
    there is more than one visual
    the default colormap is not writeable
I hacked this patch to run GRASS on some SUNS with 8 bit displays, and I
tested it on a RH6.1 Linux using startx -- -bpp 8.
(I get the same results as you did when in 8 bit mode on XFree86)
inside your grass source
  cd to
     src/display/devices/XDRIVER/XDRIVER24
and apply the attached patch
    patch -p1 < XD2.diff
then /usr/local/bin/gmake5 while in that directory
If all goes well, you should immediately be able to
   d.mon start=x0 to you hearts delight.
As a bonus if you want to force TrueColor for your 8 bit
Display (you are running XF86 3.3.5 and it supports multiple visuals)
set nlev to be -1
  d.mon start=x0 nlev=-1
on your 8 bit display you will not be able to see any difference
excepting that the color palette for the screen will be animated
as you enter the screen.
to compare
  d.mon start=x0
and
at the same time.
SUNs have overlays that allow multiple bit depths at the same time. ie
the
default visual is 8bit PsuedoColor but has 24bit TrueColor available.
DISCLAIMER:
This patch works for me but your results may vary.
I don't pretend that the code is pretty only functional (for me)
save the files
  Graph_Set.c
  SWITCHER.c
  local_proto.h
  Clr_table.c
if you want to revert the changes
or you can
  patch -p1 -R < XD2.diff
Please email the results should you try the patch.
ATTENTION:
Markus Neteler, this is not the patch I sent you over the weekend.
This
version searches for a TrueColor visual a bit harder before
dropping to the default Visual.
E-Mail: candrsn@mindspring.com
Date: Wed, 03/27/2000 12:00:00 +0000 (GMT)
Flying Monkeys Usually Mean Trouble.
(attachments)
XD2.diff (7.52 KB)
