The areas you create are not labelled (means that v.to.rast will give
you an empty file). Snapping doesn't help. Labelling is done via the
dig_att file : an entry for each area or line to be labelled made as
following for an area :A xxxxxx yyyyyy nn
A means area (L for line), xxxxx and yyyyyy are the coordinates of the
label point (inside the area), and nn is the area number (> 0).Try to use v.digit after running v.support. There is some command
to show unlabelled areas. You can label each area interactively.
If some areas cannot be labelled, look at the nodes around them (and
zoom)
If there is some green dots, that's mean that a line doesn't match
any other. You can snap manualy lines together, solving the unclosed
polygon problem. After that rerun v.support to label area, and
v.to.rast
will work.
If you have some labels in dxf, you can import them in the dig_att file
with respect to the format showed above (v.digit is sometimes boring
Well, in order to export the map into a raster format it would be a good
solution, but I want to get the areas in the vector format and export
them into a shape file. It doen't matter if the dbf file is empty, I
only want the map.
In the other hand, GRASS detect the lines not owned by areas (in v.digit
I can see these opened lines, option "o" in the Toolbox), but I cannot
create new areas from v.digit. I've tried to label all the lines of a
not detected area and after that I don't know how to make GRASS to
detect the polygon (v.support doesn't recognize it).
Besides, it would be very boring to create all the missing areas from
v.digit because I am working with big maps...
Can you help me?
Thank you for your time.
Juan Bañuls.
______________________________________________________
Get Your Private, Free Email at http://www.hotmail.com
From eicksch Fri Mar 5 13:55:05 1999
Received: from earth (localhost [127.0.0.1]) by earth.uni-muenster.de (950413.SGI.8.6.12/950213.SGI.AUTOCF) via SMTP id NAA07287; Fri, 5 Mar 1999 13:54:59 +0100
Sender: eicksch
Message-ID: <36DFD423.31DF@earth.uni-muenster.de>
Date: Fri, 05 Mar 1999 13:54:59 +0100
Organization: University of Muenster
X-Mailer: Mozilla 3.01SGoldC-SGI (X11; I; IRIX64 6.4 IP27)
MIME-Version: 1.0
To: GRASS <grassu-list@pandora.cecer.army.mil>
Subject: i.cluster / GRASS 5.0beta
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
X-Mozilla-Status: 0001
Status: O
Content-Length: 1481
Lines: 50
Hi everybody-
I have problems with i.cluster. I want to perform a unsupervized radio-
metric classification of some passive microwave images. I have success-
fully imported them into GRASS5.0beta. I created a group and a subgroup
containing four of the seven channels - each has *no* NULL or 0 values
in the region set with g.region. There is *no* mask set. g.region
reports:
GRASS 5.0beta > g.region -p
projection: 0 (x,y)
zone: 0
north: 2250000
south: 1800000
east: -100000
west: -550000
nsres: 3125
ewres: 3125
rows: 144
cols: 144
But all I get is:
GRASS 5.0beta > i.cluster group=f13_ndc_9701XX_1200
subgroup=f13_ndc_9701XX_1200 sigfile=f13_ndc_9701XX_1200.txt
classes=4
Reading image ... 100%
ERROR: Not enough non-zero sample data points. Check your current
region
(and mask)
The "source-images" or in the mapset PERMANENT not in the current
"working" one - does this matter?
Thanks in advance for any hint,
Stephan
Stephan Eickschen Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology email: eicksch@uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
http://earth.uni-muenster.de/~eicksch/
