Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
To: <grassu-list@max.cecer.army.mil>
Cc:
Subject: Re: subsetting a vector
Message not delivered to recipients below. Press F1 for help with VNM
error codes.
VNM3043: MR MARK ADAMS@TEC@FLW DCD
VNM3043 -- MAILBOX IS FULL
The message cannot be delivered because the
recipient's mailbox contains the maximum number of
messages, as set by the system administrator. The
recipient must delete some messages before any
other messages can be delivered.
The maximum message limit for a user's mailbox is
10,000. The default message limit is 1000 messages.
Administrators can set message limits using the
Mailbox Settings function available in the
Manage User menu (MUSER).
When a user's mailbox reaches the limit, the
user must delete some of the messages before
the mailbox can accept any more incoming messages.
---------------------- Original Message Follows ----------------------
To select a zone of raster map in grass we just need
to define the region and thenr.mapcalc "new.map = old.map"
Is there any way to do the same with a vector?
I have a very large vector of coastlines and I'm
interested only in one particular region.alobo@eno.princeton.edu
There is a shell programs v.clip.sh that will clip a region defined with d.zoom
This should be available on the moon ftp site. Another grass program, v.cutter
clips vectors with a "cookie cutter" vector input map.
Bill Jackson
LL-N
USA-CERL
