Undeliverable Message
Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
To: <grassu-list@max.cecer.army.mil>
Cc:
Subject: Re: subsetting a vector
Message not delivered to recipients below. Press F1 for help with VNM
error codes.
        VNM3043: MR MARK ADAMS@TEC@FLW DCD
VNM3043 -- MAILBOX IS FULL
   The message cannot be delivered because the
   recipient's mailbox contains the maximum number of
   messages, as set by the system administrator. The
   recipient must delete some messages before any
   other messages can be delivered.
    The maximum message limit for a user's mailbox is
   10,000. The default message limit is 1000 messages.
   Administrators can set message limits using the
   Mailbox Settings function available in the
   Manage User menu (MUSER).
   When a user's mailbox reaches the limit, the
   user must delete some of the messages before
   the mailbox can accept any more incoming messages.
---------------------- Original Message Follows ----------------------%%To se
lect a zone of raster map in grass we just need
%%to define the region and then
%%r.mapcalc "new.map = old.map"
%%Is there any way to do the same with a vector?
%%I have a very large vector of coastlines and I'm
%%interested only in one particular region.
%%Thanks!
%%Agus
%%Dr. Agustin Lobo
%%Instituto de Ciencias de la Tierra (CSIC)
%%Marti Franques s/n
%%08028 Barcelona (Spain)
%%tel. 34 3 330 2716
%%fax. 34 3 411 0012
%%alobo@ija.csic.es
%%alobo@eno.princeton.edu
Use v.cutter with a vector layer that defines your area of interest.
Then run v.spag -i to clean-up the cut data.
Jill
     ____ __ ________ _____ _______ .
    / \ // /____// / / ____/// /.....\/\ /\
   / \// / \\ / // / \_/\_/ \
_/ \/__/ \\_/_____\ /_____ // /\/ _/\ ---------
________________________________________/
Jill R. Schuler
USDA
Natural Resource Conservation Service
2625 Redwing, Suite 110
Ft. Collins, Co 80526
e-mail: jschuler@ftc.nrcs.usda.gov Phone: (970) 282-2418
