To:
Cc:
Subject:
Message not delivered to recipients below. Press F1 for help with VNM
error codes.
VNM3042: grassu-log@TR-S@USACERL
VNM3042 -- NAME NOT FOUND
Mail cannot deliver the message for one of the
following reasons: the appropriate StreetTalk is not
available; the recipient's user name was deleted; the
recipient's name was not entered correctly. Verify
the accuracy of the name entered. If the name you
entered is a user name, check to see if the user was
deleted. If the name is correct and the user exists,
check the connections between the recipient and
the sender.
You may see this error if you send a message to a list,
but one of the names on the list is incorrect or invalid.
Anytime a user is deleted, that user name must be
removed from all lists that contain the name.
---------------------- Original Message Follows ----------------------remote
execution [uucp job mntc600Cb347 (5/17-8:23:16)]
rmail mwirm!fjs
exited with status 1
===== stderr was =====
bad system name: mwirm
uux failed ( 11 )
rmail: Return to attmail!internet!isis.cecer.army.mil!owner-grassu
