unlocking monitor x0
Somehow, I seem to have lost the file containing current monitor status info.
When I try to start x0, I am told it is already running. When I use d.mon -L
to check monitor status, I receive nothing back. I have tried using the
stop=x0 unlock=x0 options to free x0, but his doesn't work. Where is the
file that stores current info on monitor status? Thanks for anybody's help
on this one.
Cliff Behrens
Mapset <MORENET> in Location <layers>
GRASS 4.1 > d.mon start=x0 select=x0
Graphics driver [x0] is already running
Problem selecting x0. Will try once more
GRASS 4.1 > d.mon stop=x0 unlock=x0
Monitor 'x0' terminated
GRASS 4.1 > d.mon unlock=x0
GRASS 4.1 > d.mon -L
name description status
GRASS 4.1 >
Hi Cliff,
  this is no direct answer to your question, but when we have
problems with disobedient monitors that the normal GRass options can't
solve, we do
  ps -ef|grep <monitorname>
and
  kill -9 <PID of monitor>
After that, a clean restart of the monitor is possible.
Hope this is of some use to you...
Martijn van Leusen
on this one.
Cliff Behrens
GRASS 4.1 >
