unlocking x0,x1,etc
Dear friends:
I have installed my grass under solaris now.
But, on my 1st time that I exited from grass-shell
I forgot two (x0-x1) display monitor active and
now I can't use this two monitor on other sessions!
Could someone help-me?
Miltinho (RIBEIRO, M.C.)
Quantitative Methods Laboratory
Forest Science Department
ESALQ/University of Sao Paulo
13418-900 - Piracicaba - SP
Brazil
Milton Cezar Ribeiro wrote:
Dear friends:
Could you use the ps command (from the unix shell), find which processes
are running x0 and x1, and use the kill command to shut them down?
/* Paul Box | Cogito ergo */
/* Dept. of Geography | Oculum Dioscoreum */
/* University of Florida | */
/* sanduku@nervm.nerdc.ufl.edu | (I think, therefor */
/* http://grove.ufl.edu/~sanduku | eye yam) */
The happened to me also. Even I killed the processes, I could not run x0
again. Seems there is a lock file somewhere that control the devices.
Peizhong
University of Michigan
> Dear friends:
This would be a lock file under $GISBASE/locks/<machine_name>/. The
difficulty is in associating the correct lock file with the monitor. If
you can be sure that all monitors have been stopped that are running
from a particular machine, you can simply remove all lock files under
that machine name.
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
Peizhong
> > Dear friends:
