Updates
|I'd like to make a suggestion to those of you who are responsible for
|putting updates to GRASS 4.0 on the moon. I just went through the
|rather painful exercise of downloading all the *.cpio.Z files from the
|moon, and installing those updates. The problem/nuisance is that the
|directory hierarchy is not consistently saved in the cpio files, which
|makes it very labor intensive to install updates (one must first
|check the cpio table of contents to see where it should be extracted
|to).
|My suggestion is therefore to uniformly use relative pathnames to the
|installed GRASS 4.0 root src directory.
|Similarly for src.{alpha,contrib,related}.
     Very good suggestion. It's something I'm working on right now. It may
take a while to resave all the cpio files, but it should only be a couple more
days.
     The paths will start at src{.alpha,.conrtib,.related}
|Tschuess ...rick...
|______________________________________________________________________________
|Richard Wagener |
|Bldg. 426, rm. 43 | IP: wagener@bnl.gov
|Environmental Chemistry Division | DEC: 44048::rwagener
|Brookhaven National Laboratory | phone: 1-516-282-5886
|Upton, New York 11973, U.S.A. | fax: 1-516-282-2887
                                                        Ken.
                                           brownfld@zorro.cecer.army.mil
                                               Kenneth R. Brownfield
