To be able to create high resolution (2000 x 2666) PostScript output to a
slidewriter, I uncommented the lines pertaining to the CELL monitor in
the monitorcap file and inserted CELL_HEIGHT and CELL_WIDTH values into
my .grassrc file. I then started the CELL monitor, set the region to
contain a very high number of cells, and issued display commands for
several map layers. Stopping the CELL monitor, I expected the newly
created raster map layer D_cell to have a 2000 x 2666 size, but it
didn't. It was only 640 x 480 cells in size. I suspect this must have
been hardwired in the CELL driver. Can anyone confirm this and supply a
method of changing these values?P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam martijn@scanner.frw.uva.nl
Martijn,
The variables in .grassrc are not automatically exported to your environment.
You can either set these environmental variables manually ( setenv CELL_HEIGHT
2666, etc., if you are running csh), or have them set automatically by
creating a .grass.cshrc file in your home directory with these variables
added to it (normally, copy your standard .cshrc to .grass.cshrc and edit it).
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
