Hello all,
Is there a way of setting up GRASS so that I can use the GRASS commands directly
from
the UNIX prompt. I faintly recall that there was some suggestion for doing this
sometime
on this ML but I am unable to locate the answer now.
Thanks in advance
Venkatesh raghavan
Hello Venkatesh
directly from the UNIX prompt. I faintly recall that there was some
suggestion for doing this sometime on this ML but I am unable to locate the
answer now.
Why can't you use the standard grass commnad line interface (running
grass4.2.1)? When you run this command it provides you with a unix shell
capable of running any unix command. The only difference between this shell and
a regular unix shell is that there are GRASS environment variables set that
allow the grass commands to run.
Is there another problem you are having?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
I would like to call some GRASS programs (without starting the GRASS Shell)
from other programs that I am writing in FORTRAN.
I recall that there were some previous mention about doing this be cannot
locate the info in the ML archives.
Thanks
Justin Hickey wrote:
Hello Venkatesh
> answer now.
Sincerely,
Bangkok, Thailand
