Using Laserjet 4
If your Laserjet 4 has the Postscript option, you'll need to copy the
following file into the directory
'/grass4.1/etc/paint/ps.devices' as e.g. 'laser4'
Then when you're running GRASS, use 'ps.select' and hopefully away you go
creating maps using 'ps.map'.
Hope this helps,
Steve Culshaw
NRA North West
e-mail : nra@cix.compulink.co.uk (use this for general usage)
or sculshaw@cix.compulink.co.uk (Private - only checked at best
biweekly)
