Date: Tue, 14 Dec 93 08:52:48 CST
From: "garvinc@sill-emh.army.mil (Chris D Garvin)" <GARVINC@SILL-EMH.ARMY.MIL>
Subject: utm spheroid clarke 1886
To: <grassu-list@max.cecer.army.mil>Regarding the difference between clark 66 and clark 88; there will definatly
be a differance between the two projections! The difference will be on the
order of a few hundred feet on both the x and y axis. I have also had problems
with some programs not having the correct projection. This is especially true
with the SCS MAPGEN interface.regards,
Chris D Garvin--Ft Sill,OK
Two questions:
1) If there is a Clarke 1888 ellipsoid, what are its parameters?
2) What do you mean by "not having the correct projection" above?
Thanks.
Gerald (Jerry) I. Evenden Internet: gie@charon.er.usgs.gov
voice: (508)563-6766 Postal: P.O. Box 1027
fax: (508)457-2310 N.Falmouth, MA 02556-1027
