Subject: UTM zones - west edge, overlap, v.mkquadsCan someone provide a quick lesson on the nature of UTM
zones? I thought there was some overlap between adjacent
zones, with low eastings in one zone overlapping with the
high eastings of the neighboring zone on the west. True?
The only match is the northing value for adjacent zone will match
at the seam mid-way between the zones (where longitude evenly
divisible by 6 degrees).
Why I ask: I need a vector layer of USGS quadrangle edges
in a location that is on the west edge of zone 12. If
I run v.mkquads with a very low number for the west edge
of the current region, v.mkquads fails with this message:Zone of the given point (zone: 11) does not match zone of the current window 12
Can't go across UTM zones.This message is received with any west edge set to less than 218244.
Oddly, the east side of the region seems to be extensible for quite
a distance, with v.mkquads working fine with an east edge
of, for example, 1500000.Theoretically, doesn't a UTM zone have a west edge of zero?
And what's so magical about E218244?thanx
Scott Wade
wade@zorro.cecer.army.mil
This is an endemic problem.
UTM is a fine projection when used withing the constraints of its
definition: large scale mapping in regions that can be contained in
its zone system. But when attempting to use it outside these
restrictions, all Hell breaks loose.
The most appropriate answer for this problem is to not use UTM, but
this gets into all the details for making an appropriate choice.
Users want something simple when the right answer is not simple,
but there HAS to be something better than UTM.
To Scott: sorry I did not fully answer your questions, but I am
getting stressed over the over/mis-use of UTM. If you have
the flexibility of using something other than UTM and want
some help, please contact me direct.
Gerald (Jerry) I. Evenden Internet: gie@charon.er.usgs.gov
voice: (508)563-6766 Postal: P.O. Box 1027
fax: (508)457-2310 N.Falmouth, MA 02556-1027
