v.db.rim: .v (vector map creation)
After importing a county's worth of TIGER data into RIM and performing a query
that selects all roads, the .v operation, creation of a new vector map, fails
with a message repeated for every record on the query list : 'Warning no line
number (0) found for record number' <the RECNUM field value, ie. the TIGER
line segment id>.
If I let this crank through the entire query list, no new vector map is
produced.
Can someone help us with this?
thank you.
allan
