v.digit and Solaris 2.4
Hi folks...
There seem to be a number of opinions on Sol2.4 and v.digit.
e.g.
Subject: Re: Altek Digitizer
Well, apparently the v.digit program doesn't work with under Solaris 2.4.
This is probably true for all System V operating systems. So you were right
about using the v.digit2 program instead.
...on the other hand...
> Paul,
> Does v.digit allegedly run okay with Solaris 2.4?
> -Malcolm Williamson
Yes, I have this setup running OK (with a Genitizer GT1812 though)
So, can anyone elaborate? Any ideas on what conditions must be met in
order to make v.digit go under s2.4?
I've got a Kurta XGT, and it works with arc/info, so I know the comms
is OK. In v.digit all I get is 'digitizer read error'.
Thanks
David Houlder Phone: +61 6 249 4613
Geography Department (In Aust.: (06) 249 4613)
The Australian National University Fax: +61 6 249 3770
