v.digit driver?
I requested help using v.digit without a digitizer. When I select [none]
as my digitizer I get the message:
sh: /usr2/local/grass4.0/etc/dig_drivers/none/digit: not found
Cristina Seabra suggested:
Hello Doug,
You have to create a file in your /usr2/local/grass4.0/etc/ named digcap that
has the information that the driver being used is none.It can be like this:
none:nodig:nofile: Run digit without the digitizer.
I tried variants of Cristina's suggestions. I believe the file is digitcap,
not digicap, and I tried changing "none:nodig:digit: Run digit without the ..."to "none:nodig:nofile: Run digit without the digitizer"
but this only produced the error message:
sh: /usr2/local/grass4.0/etc/dig_drivers/none/nofile: not found
Since I didn't have a file "nofile" or "digit" in the dig_drivers/none/
directory I created one without anything in it, but it didn't change
the response of the program. Do I need to put anything in this
Does anyone else have any idea what might be the problem?
Thanks.
________________________________________________________________
Doug Hersh Boston University Marine Program
dhersh@lupine.mbl.edu Marine Biological Laboratory
(508)548-3705 ext. 516 Woods Hole, MA 02543
>From: cis@lua.cecer.army.mil
>Hello Doug,
not digicap,
For GRASS 4.0's v.digit and GRASS 4.1's v.digit2 (same as GRASS 4.0), the
correct file is "digitcap" (digcap is only for GRASS 4.1's v.digit).
"none:nodig:digit: Run digit without the digitizer." is the correct entry.
You seem to missing the whole point here, the third parameter in the
digitcap entry is the actual name of a binary executable program, which is
the basic v.digit program with appropriate code added for the particular
digitizer in question. In your case
/usr2/local/grass4.0/etc/dig_drivers/none/digit is where the version
particular to having no digitizer should be found. You will have to
compile this version of v.digit before it will work.
Lawrence Houston - (houston@norton.geog.mcgill.ca)
