v.digit problems
Is it just me or is it impossible to set a digitizing and snapping theshold
in v.digit (grass 4.0) when working with a x-y coordinate system based location.
Digitizing is very hard when you have to snap everything manually (no, v.spag or
v.support won't do the job).
Is this problem solved in 4.1 ?? or is there a sollution. My guess is that
it is connected to the weird assumption GRASS makes about my map-scale.
Olga van de Veer
nieuwlnd@sci.kun.nl
