v.digit -Reply -Reply -Reply
In an E-mail message, Gerald Nelson wrote:
My problems with v.digit arose because v.support was not working
correctly. I was originally using the latest source code and compiling it.
When I went back to the 4.1.3 binaries on moon and grabbed the
relevant files (v.support, v.build) things worked as they were supposed
to. I suspect I don't have all my parameters correct in the compile setup,
but for now everything seems to be fine. Thanks to all for your advice.
Jerry Nelson
Jerry,
Are you running on a Sun or SGI?
Paul Loechl p-loechl@cecer.army.mil
USA CERL (217)352-6511x7668
