v.digit using Altek AC30 (Problems)
> I am attempting to run v.digit using an Altek AC30 digitizer (format 8,
> 9600 baud) using the al30f8_16 driver. The problem I run into is when I
> attempt to register a map. I am able to enter the coordinates (using the
> keyboard) and then register the points (using the digitizer cursor). When
> I press Key<4> (accept residuals), the program bails out at the verify
> screen and returns the message "Digitizer read error: exiting" at which
> point I am then back at the GRASS4.1> prompt. I have checked the dip
> switches on the digitizer and everything appears to be in order. Has
> anyone else experienced a similar problem? Any suggestions?
I have exactly the same problem with the new v.digit. Please help !!!
The only difference for me is that I have a AC40 controller, but that
shouldn't change anything in the setup. This has been a unsolved problem
for me for a long time, but I haven't had the time to dig deep into the
problem.
Lars
Lars Schylberg Email: larss@fmi.kth.se
Dept. of Geodesy and Photogrammetry
Royal Institute of Technology (KTH) Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
Well, I have experienced this problem about a month ago. I thought it
was an error in my digitizer setup file and haven't really looked at it
since then. However, we use a *Summagraphics Microgrid III*. So, I
guess it's in the code.
Raymond Venneker - Earth Sciences, Free University Amsterdam
