Jim,
You need to change the type of line you have to an area edge.
You can do this wihtin v.digit edit menu with the t command.
Or you can cd to the dig_att direcotry and change the L to A using a global
change. Then run v.support. If I were you I would make a copy of your layer
before I did this.
Greg Thacker
USACERL TAC
