Message-Id: <9207142121.AA14394@nova.ccrs.emr.ca>
Subject: v.digit
Sender: lists-owner@amber.cecer.army.mil
Reply-To: grassu-list@amber.cecer.army.mil
Precedence: Bulk
Date: Tue, 14 Jul 92 17:21:03 EDT
Cc: kushigbo@ccrs.emr.ca (C. Kushigbor), henning@ccrs.emr.ca (Leo Henning)---------------------------------------------------------------
Mark Dostie
System Support and Integration
MDA / Ottawa Engineering
X-Mailer: ELM [version 2.3 PL0]Good Afternoon,
I would really appreciate a quick answer on this ( doesn't everyone? ),
what we are trying to do is seperate the code which is specific to
the v.digit application from the Grass system.In other words, we are trying to put all the v.digit files ( any
which are relevant ) into a directory with their include files and
the related library files and then have a Makefile which generate
the executable v.digit*Could you provide a list of the necessary files (.c) and perhaps
a sample Makefile ( or Gmakefile ) which can be used outside of
the Grass environment.Thank you for your assistance in advance.
Mark Dostie
My first response to this was lost by the list server so I am retyping
this in from a printout that I managed to save. Any previous responses
I have posted to other queries seem to be lost. My appologies.
Digit relies on:
src/libes/gis # General GRASS library
src/libes/vask # Visual forms library
src/libes/dig_ascii # dig_ascii support
src/libes/D # high level video routines
src/libes/display # low level video routines
src/libes/raster # lower level video routines
src/mapdev/Vlib # high level vector library
src/mapdev/diglib # low level vector library
src/mapdev/v.digit # v.digit source code
src/mapdev/bin_digit # separate front end program
src/mapdev/digitizers/* # directories for each digitizer driver
# v.digit is actually compiled from here
Then you need a GRASS video driver running, which are in:
src/display/devices/* # directories for each video driver
which also need:
src/display/devices/lib # common library for vid drivers
(src/libes/D) # for some reason XDRIVER links this in
Then if you want to use gmake4.0, you will need the CMD directory with
the support programs:
src/CMD/* # GISGEN, setup, etc
Then with all that, I would think you will want the GRASS file manipulation
programs like g.list, g.remove, etc.
src/general/manage
Then there is the stuff that gets the user into GRASS
src/general/gis # you might want to strip some of this out
Then there are the display manipulation routines: d.mon, d.erase, d.vect, etc:
src/display/* # or as much as you want
Then there are the vector manipulation routines like v.support, v.clean,
v.in/out.ascii, v.in/out.dlg, v.patch, v.prune, etc.
src/mapdev/* # or as much as you want
Then assuming you want all that is above, you probably want man pages:
src/general/g.manual
man
I would say that v.digit would probably be a little difficult to separate
from GRASS.
Dave Gerdes
US Army Construction Engineering Research Lab
Spatial Analysis & Systems Team
dpgerdes@cerl.cecer.army.mil
(217) 352-6511 x591
