Cristina Seabra,
There should be a file in $GISBASE/etc called
digcap.sampl . Copy this file to digitcap
then edit it to reflect your set up (ie, the
driver you need and the serial port the digitizer
is connected to).
Mark Johnson - USACERL
Cristina Seabra,
is connected to).
