Can anyone tell me what is wrong with the included text file[s].
I am trying to import a simple ungen file set with v.in.arc. But when
I run v.in.arc with the text file option it doesn't import giving the
error:
v.in.arc: Coverage type = polygon
The LABEL-TEXT file has been scanned. There are 15
lines in the file and 3 columns in the file
Working...
ERROR: Reading LABEL-TEXT or LABEL-POINTS file
It imports the lines file OK (without the text_in option.)
The command is:
v.in.arc lines_in=simple.pol points_in=simple.lab \
text_in=simple.txt vector_out=simple idcol=1 catcol=3 type=polygon
I've tried both GRASS4.2.1 and GRASS5beta6, also with
an optional 'END' line on each file in all combinations.
Also it says 15 lines: I count 14. . .
Any help appreciated.
D Gray
(attachments)
simple.lab (425 Bytes)
simple.txt (336 Bytes)
Hi David,
this might be related to G_strip commands used there.
Please try if you change G_strip to G_squeeze.
Reason could the the changes from gets to fgets
and related stuff.
Hope this helps (if you get it, please send me
the diffs for the CVS).
Markus Neteler
Geographisches Institut | Schneiderberg 50
+ Physische Geographie 30167 Hannover, Germany
& Landschaftsoekologie + Tel: ++49-(0)511-762-4494
Universitaet Hannover Fax: ++49-(0)511-762-3984
neteler@geog.uni-hannover.de
error:
Working...
The command is:
D Gray
Markus Neteler wrote:
Hi David,
and related stuff.
Markus Neteler
> D Gray
Hi
Actually I must have missed a combination. It _was_ because of
the .lab file not having an END statement. I thimk perhaps I
forgot an EOL, and that's why it didn't pick this up.
Otherwise the build with 'G_squeeze' is working fine.
David.
