I've been using v.in.arc to import some data the Forest Service has graciously
provided me. Every time there is an ID # greater than 3 digits long the program
chokes on it and gives the error message "ERROR: Premature Text-Label EOF.
ID #xxxx not found."
Is this a bug or a limitation in v.in.arc? If I change the 4 digit numbers to
99 or less v.in.arc has no problem. I'd like to know if that is what I need to
do or if there is another work-around. I have alot of files so I'd ideally like
to avoid the editing!
thanks in advance,
ken
