2006/11/21, Hamish <hamish_nospam@yahoo.com>:
Martin Landa wrote:
> > https://intevation.de/rt/webrt?serial_num=5209
> I have tried to fix this bug (the attached patch). Is it OK? -- then I
> will commit it to CVS...re. "column type" text, it is probably not a good idea to mix
fprintf(stderr, and G_message(). I can see why you kept the first bit
with fprintf (no newline), but the module output will look really weird
if called with the --quiet flag as only G_message() part would disappear.
ou, sorry, ... you are absolutely right...
What seems to be needed is a G__message() or G_message_no_newline() or
somesuch fn that doesn't terminate with a newline.
I have tried to modify error.c, there is the new G__message () fn.
Best regards, Martin
This could be used for "Percent complete:"+G_percent() as well.
Then both msgs get switched on/off together with quiet/verbose.The following looks good to me, but to preserve precision should "%lf"
be used instead of "%f", perhaps combined with G_trim_decimal()?Index: vector/v.in.ascii/points.c
RCS file: /home/grass/grassrepository/grass6/vector/v.in.ascii/points.c,v
retrieving revision 1.21
diff -u -r1.21 points.c
--- vector/v.in.ascii/points.c 18 Oct 2006 05:09:22 -0000 1.21
+++ vector/v.in.ascii/points.c 19 Nov 2006 16:45:25 -0000
@@ -368,7 +368,15 @@
if (strlen(tokens[i]) > 0) {
if (coltype[i] == DB_C_TYPE_INT ||
coltype[i] == DB_C_TYPE_DOUBLE) {
- sprintf(buf2, "%s", tokens[i]);
+ if (G_projection() == PROJECTION_LL &&
+ (i == xcol || i == ycol)) {
+ if (i == xcol)
+ sprintf(buf2, "%f", x);
+ else
+ sprintf(buf2, "%f", y);
+ else
+ sprintf(buf2, "%s", tokens[i]);
else {
db_set_string(&val, tokens[i]);thanks,
Hamish
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
(attachments)
v_in_ascii_LL-2.diff.gz (1.53 KB)
