v.in.ascii
From grass-lists-owner@max.cecer.army.mil Fri May 21 07:57:18 1993
Date: Fri, 21 May 1993 08:48:30 -0400
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Subject: Re: v.in.ascii
Content-Length: 255
Thanks, Cristina.
I was aware of dig_att. SO I tried v.out.ascii
"quads" (the simpliest layer in spearfish).
I had both dig_ascii and dig_att. Then I did
v.to.rast. I got a layer with one category only.
I got lost.
--Xin Zhuang
zhuang@access.digex.com
Zhuang Xin,
  You need to run v.support to build a dig_plus file which is generated
fromm both dig and dig_att files, then try v.to.rast again.
  Godd Luck !
Wang Song
wang@cast.uark.edu
