v.in.ascii
Hello,
  I am presently trying to convert lat-lon coordinates into vector maps.
I have successfully converted the data into UTM form with the m.ll2u command
and then put it into grass ascii format using an awk program. I then use the
v.in.ascii command and a vector map is created. This is where I run into
trouble. When I use the d.vect command the map does not display. I tried
other maps that had been create other ways and they work so I don't know what is
wrong. The map that I created is within the region so it should display. If
there is anything that I didn't do or set please respond.
Dan Reilly
Ocean Engineering
University of Rhode Island
